Saltar al contenido principal
ASUS MeMo Pad FHD10 Battery Replacement
Qué necesitas
  1. ASUS MeMo Pad FHD10 Battery Replacement, Battery: paso 1, imagen 1 de 2 ASUS MeMo Pad FHD10 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure that the device is turned off as a precaution.
    • Unplug the charger and remove any memory card you may have in the device.
    • Wedge the plastic opening tool between the front and back cover on every side.
    • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
    • Once disconnected, remove the back cover from the device screen.
  2. ASUS MeMo Pad FHD10 Battery Replacement: paso 2, imagen 1 de 2 ASUS MeMo Pad FHD10 Battery Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the protective copper sticker and all tape fixed on the device.
    • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
    • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
  3. ASUS MeMo Pad FHD10 Battery Replacement: paso 3, imagen 1 de 2 ASUS MeMo Pad FHD10 Battery Replacement: paso 3, imagen 2 de 2
    • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
  4. ASUS MeMo Pad FHD10 Battery Replacement: paso 4, imagen 1 de 3 ASUS MeMo Pad FHD10 Battery Replacement: paso 4, imagen 2 de 3 ASUS MeMo Pad FHD10 Battery Replacement: paso 4, imagen 3 de 3
    • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
    • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
    • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
Conclusión
5 personas más completaron esta guía.
Dmitry
Miembro Desde 01/21/15
391 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 9-5, Blackwell Winter 2015 Miembro de USF Tampa, Team 9-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G5
4 Miembros
10 Guías creadas
Un comentario
Where i can get new battery for this tablet?
Night Knight - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 20
Todo El Tiempo: 9,693
