Saltar al contenido principal
ASUS Laptop Battery, SSD, and RAM Removal
Qué necesitas
  1. ASUS Laptop Battery, SSD, and RAM Removal, Unscrew the Back Cover: paso 1, imagen 1 de 2 ASUS Laptop Battery, SSD, and RAM Removal, Unscrew the Back Cover: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $16.96
    • Remove the 11 screws securing the back panel.
    • Don't forget the screw hidden inside the SD card slot — this one is easy to miss.
    • Screw lengths may vary. Keep track of their original positions using a magnetic project mat or labeled containers.
  2. ASUS Laptop Battery, SSD, and RAM Removal, Pry Open the Back Cover: paso 2, imagen 1 de 2 ASUS Laptop Battery, SSD, and RAM Removal, Pry Open the Back Cover: paso 2, imagen 2 de 2
    iFixit Opening Tool
    $1.99
    • Use a plastic opening tool to gently separate the back cover from the chassis.
    • Start on one side (left or right) and carefully work your way around the entire perimeter.
    • Take your time to avoid damaging clips or scratching the surface.
    • If the cover feels stuck, double-check that all screws are fully removed — especially the one in the SD slot.
  3. ASUS Laptop Battery, SSD, and RAM Removal, Remove the Battery: paso 3, imagen 1 de 1
    • Locate the two screws securing the battery.
    • These screws won’t come out completely — just loosen them until they turn freely.
    • Lift the small black tab upward to disconnect the battery from the motherboard.
    • Gently remove the battery and set it aside.
  4. ASUS Laptop Battery, SSD, and RAM Removal, Remove the SSD: paso 4, imagen 1 de 2 ASUS Laptop Battery, SSD, and RAM Removal, Remove the SSD: paso 4, imagen 2 de 2
    • Remove the single screw holding the SSD in place.
    • It's very small — don’t lose it.
    • Pull the SSD out in the direction it’s facing (usually upward at a slight angle).
    • Avoid bending or twisting the drive during removal.
  5. ASUS Laptop Battery, SSD, and RAM Removal, Remove the RAM Module: paso 5, imagen 1 de 1
    • Locate the metal retaining tabs on each side of the memory stick.
    • Pull the left tab to the left and the right tab to the right.
    • The RAM will pop up at an angle.
    • Gently slide it out of the slot.
    • To reinstall or replace it, insert the module at an angle, then press it down until it clicks into place.
    • To reassemble your device, follow the steps in reverse order, carefully reconnecting each component. Pay close attention to:
    • Proper alignment of connectors (especially the battery tab and SSD)
    • Returning each screw to its original position — screw lengths may vary
    • Gently snapping the back cover into place before tightening screws
    • Use your magnetic mat or photos from disassembly to double-check part placement before powering on the device.
Conclusión
If your laptop doesn’t power on after reassembly or shows unusual behavior, don’t worry — it may just be a loose connector or unseated component.
ThorTheMainGod
Miembro Desde 06/24/25
181 Reputación
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 34
Ultimos 30 días: 133
Todo El Tiempo: 465
