Saltar al contenido principal
ASUS K53E-BBR1 Keyboard Replacement
Qué necesitas
  1. ASUS K53E-BBR1 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Lift the monitor up so that the keyboard is visible.
    • You will notice five spots on the top of the keyboard where the iFixit opening tool should be placed.
  2. ASUS K53E-BBR1 Keyboard Replacement: paso 2, imagen 1 de 3 ASUS K53E-BBR1 Keyboard Replacement: paso 2, imagen 2 de 3 ASUS K53E-BBR1 Keyboard Replacement: paso 2, imagen 3 de 3
    • Use the iFixit opening tool on each of the designated spots to pry the keyboard apart from the palm rest.
    • You will hear a light "pop" sound each time you pry the keyboard.
    • Once the keyboard is loose, do not pull keyboard far (more than 3 inches) apart from the from the palm rest. There is a "bus" connector attached to the bottom.
  3. ASUS K53E-BBR1 Keyboard Replacement: paso 3, imagen 1 de 1
    • Carefully disconnect the "bus" connector from the laptop. Press on it with your thumb/index finger and slide it right along the surface of the laptop.
Conclusión
Paulo Fortes
Miembro Desde 03/20/19
147 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 329
