Saltar al contenido principal
ASUS K53E-BBR1 Hard Drive Replacement
Qué necesitas
  1. ASUS K53E-BBR1 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop over so you can see the battery.
  2. ASUS K53E-BBR1 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Slide the lock on the right side of the battery to the right. If done correctly the slider will stay in place and there will be a red indicator.
  3. ASUS K53E-BBR1 Hard Drive Replacement: paso 3, imagen 1 de 3 ASUS K53E-BBR1 Hard Drive Replacement: paso 3, imagen 2 de 3 ASUS K53E-BBR1 Hard Drive Replacement: paso 3, imagen 3 de 3
    • Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop.
  4. ASUS K53E-BBR1 Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 2 ASUS K53E-BBR1 Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 2
    • Remove the two 4mm Phillips #0 screws on either side of the laptop.
  5. ASUS K53E-BBR1 Hard Drive Replacement: paso 5, imagen 1 de 2 ASUS K53E-BBR1 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Slide the back panel towards you until it stops.
    • Lift the panel up out of the laptop casing.
  6. ASUS K53E-BBR1 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Remove the four 3mm Phillips #0 screws holding the hard drive in place.
  7. ASUS K53E-BBR1 Hard Drive Replacement: paso 7, imagen 1 de 1
    • Disconnect the hard drive from the laptop by sliding it towards the outside edge.
  8. ASUS K53E-BBR1 Hard Drive Replacement: paso 8, imagen 1 de 2 ASUS K53E-BBR1 Hard Drive Replacement: paso 8, imagen 2 de 2
    • Grab hold of the black cloth tab and pull the hard drive out from the laptop.
Conclusión
Matthew Merlo
Miembro Desde 03/20/19
267 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 257
