Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
If you have found that your battery needs to be replaced, this guide will show you how to take the old battery out. This guide is very simple and doesn’t require any tools.
  1. Flip the laptop over so you can see the battery.
    • Flip the laptop over so you can see the battery.
  2. Slide the lock on the right side of the battery to the right. If done correctly the slider will stay in place and there will be a red indicator.
    • Slide the lock on the right side of the battery to the right. If done correctly the slider will stay in place and there will be a red indicator.
  3. Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop. Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop. Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop.
    • Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop.
Conclusión
Matthew Merlo
Miembro Desde 20/03/19
267 Reputación
2 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 127
