Saltar al contenido principal
ASUS K43SV SSD Replacement
Qué necesitas
  1. ASUS K43SV SSD Replacement, SSD: paso 1, imagen 1 de 1
    • Disconnect the ASUS k43sv laptop from the external power supply before starting.
    • Place the laptop on a flat table with its back facing up.
  2. ASUS K43SV SSD Replacement: paso 2, imagen 1 de 1
    • Slide the latch on the right side of the battery on the back of the laptop to the right to the unlocked position.
  3. ASUS K43SV SSD Replacement: paso 3, imagen 1 de 3 ASUS K43SV SSD Replacement: paso 3, imagen 2 de 3 ASUS K43SV SSD Replacement: paso 3, imagen 3 de 3
    • With your left hand, slide the latch on the left side of the battery to the left and hold it.
    • With your right hand, slide the battery out of the battery compartment and place the battery away from the laptop.
  4. ASUS K43SV SSD Replacement: paso 4, imagen 1 de 2 ASUS K43SV SSD Replacement: paso 4, imagen 2 de 2
    • Remove the two screws on the bottom of the laptop using a Phillips #0 screwdriver.
  5. ASUS K43SV SSD Replacement: paso 5, imagen 1 de 3 ASUS K43SV SSD Replacement: paso 5, imagen 2 de 3 ASUS K43SV SSD Replacement: paso 5, imagen 3 de 3
    • Slide the hard disk compartment cover towards you with both hands and remove it from the laptop.
  6. ASUS K43SV SSD Replacement: paso 6, imagen 1 de 3 ASUS K43SV SSD Replacement: paso 6, imagen 2 de 3 ASUS K43SV SSD Replacement: paso 6, imagen 3 de 3
    • Remove the four screws from the hard drive support arm using a Phillips #0 screwdriver.
  7. ASUS K43SV SSD Replacement: paso 7, imagen 1 de 3 ASUS K43SV SSD Replacement: paso 7, imagen 2 de 3 ASUS K43SV SSD Replacement: paso 7, imagen 3 de 3
    • Lift the plastic sheet on the left side of the hard drive slightly by hand.
    • Remove the hard drive and its support from the hard drive compartment.
  8. ASUS K43SV SSD Replacement: paso 8, imagen 1 de 3 ASUS K43SV SSD Replacement: paso 8, imagen 2 de 3 ASUS K43SV SSD Replacement: paso 8, imagen 3 de 3
    • Remove the four screws on the side of the hard disk support using a Phillips #0 screwdriver.
Conclusión
3 personas más completaron esta guía.
Duanrui Liu
Miembro Desde 09/20/21
303 Reputación
1 Guía escrita
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 52
Todo El Tiempo: 2,116
