Introducción
This guide will show you how to replace the track pad on as Asus K200MA laptop.
Qué necesitas
With the opening facing you, flip the laptop over and remove the following screws from the back panel:
Six 4mm Phillips screws using a Phillips #0 screwdriver.
One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
Gently pull the narrow connector away from the keyboard.
