Saltar al contenido principal
ASUS K200MA-DS01T Fan Replacement
Qué necesitas
  1. ASUS K200MA-DS01T Fan Replacement, Back Panel: paso 1, imagen 1 de 2 ASUS K200MA-DS01T Fan Replacement, Back Panel: paso 1, imagen 2 de 2
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Fan Replacement: paso 2, imagen 1 de 2 ASUS K200MA-DS01T Fan Replacement: paso 2, imagen 2 de 2
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Fan Replacement: paso 3, imagen 1 de 1
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Fan Replacement: paso 4, imagen 1 de 3 ASUS K200MA-DS01T Fan Replacement: paso 4, imagen 2 de 3 ASUS K200MA-DS01T Fan Replacement: paso 4, imagen 3 de 3
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
  5. ASUS K200MA-DS01T Fan Replacement, Keyboard: paso 5, imagen 1 de 2 ASUS K200MA-DS01T Fan Replacement, Keyboard: paso 5, imagen 2 de 2
    • To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
    • Gently pull the narrow connector away from the keyboard.
  6. ASUS K200MA-DS01T Fan Replacement: paso 6, imagen 1 de 2 ASUS K200MA-DS01T Fan Replacement: paso 6, imagen 2 de 2
    • Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
  7. ASUS K200MA-DS01T Fan Replacement, Battery: paso 7, imagen 1 de 2 ASUS K200MA-DS01T Fan Replacement, Battery: paso 7, imagen 2 de 2
    • Flip the computer over so that the side with the motherboard (large green piece) is laying face-up.
    • Remove the following screws from the middle and far ends of the battery:
    • Three 4mm Phillips screws using a Phillips #0 screwdriver.
    • The battery will be located closest to the screen.
  8. ASUS K200MA-DS01T Fan Replacement: paso 8, imagen 1 de 3 ASUS K200MA-DS01T Fan Replacement: paso 8, imagen 2 de 3 ASUS K200MA-DS01T Fan Replacement: paso 8, imagen 3 de 3
    • Gripping the wider left section, lift the battery up and away from computer.
  9. ASUS K200MA-DS01T Fan Replacement, Fan: paso 9, imagen 1 de 2 ASUS K200MA-DS01T Fan Replacement, Fan: paso 9, imagen 2 de 2
    • Locate the fan, two screws and two color coded wires in the bottom left corner of the computer.
  10. ASUS K200MA-DS01T Fan Replacement: paso 10, imagen 1 de 1
    • Remove the following screws from the fan:
    • Two 4mm screws using a Phillips #0 screwdriver.
  11. ASUS K200MA-DS01T Fan Replacement: paso 11, imagen 1 de 2 ASUS K200MA-DS01T Fan Replacement: paso 11, imagen 2 de 2
    • Firmly pull colored wires away from wire slot.
  12. ASUS K200MA-DS01T Fan Replacement: paso 12, imagen 1 de 2 ASUS K200MA-DS01T Fan Replacement: paso 12, imagen 2 de 2
    • After removing both the screws and color coded wires, lift fan out of place.
    • Tools such as spudgers or tweezers may be used for fan removal.
Conclusión
Una persona más ha completado esta guía.
Terrinda
Miembro Desde 09/17/18
526 Reputación
4 Guías creadas
Equipo
CSU Fullerton, Team S2-G5, Bruce Fall 2018 Miembro de CSU Fullerton, Team S2-G5, Bruce Fall 2018
CSUF-BRUCE-F18S2G5
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 100
