Saltar al contenido principal
ASUS K200MA-DS01T Back Panel Removal
Qué necesitas
  1. ASUS K200MA-DS01T Back Panel Removal, Back Panel: paso 1, imagen 1 de 2 ASUS K200MA-DS01T Back Panel Removal, Back Panel: paso 1, imagen 2 de 2
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Back Panel Removal: paso 2, imagen 1 de 2 ASUS K200MA-DS01T Back Panel Removal: paso 2, imagen 2 de 2
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Back Panel Removal: paso 3, imagen 1 de 1
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Back Panel Removal: paso 4, imagen 1 de 3 ASUS K200MA-DS01T Back Panel Removal: paso 4, imagen 2 de 3 ASUS K200MA-DS01T Back Panel Removal: paso 4, imagen 3 de 3
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
Conclusión
Equipo
CSU Fullerton, Team S2-G5, Bruce Fall 2018 Miembro de CSU Fullerton, Team S2-G5, Bruce Fall 2018
CSUF-BRUCE-F18S2G5
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 210
