Saltar al contenido principal
ASUS F555UA-EH71 Battery Replacement
Qué necesitas
  1. ASUS F555UA-EH71 Battery Replacement, Keyboard Panel: paso 1, imagen 1 de 1
    • Remove the ten 18 mm screws holding down the outer shell of the laptop using the Phillips #000 screwdriver.
  2. ASUS F555UA-EH71 Battery Replacement: paso 2, imagen 1 de 2 ASUS F555UA-EH71 Battery Replacement: paso 2, imagen 2 de 2
    • Use your fingers to gently pry open the gap between the silver and black parts of the casing.
    • Separate the keyboard panel from the body of the laptop by wedging the iFixit Opening Tool in between the keyboard panel and the body.
    • The teeth of the casing should make a clicking noise as they’re pulled apart.
  3. ASUS F555UA-EH71 Battery Replacement: paso 3, imagen 1 de 1
    • Gently open the casing until the white, silver, and gold power strips are visible. Gently peel the strips from the bottom side of the laptop.
    • Disconnect the two cables connecting the keyboard panel to the laptop.
  4. ASUS F555UA-EH71 Battery Replacement: paso 4, imagen 1 de 1
    • Remove the keyboard panel from the laptop.
  5. ASUS F555UA-EH71 Battery Replacement, Battery: paso 5, imagen 1 de 3 ASUS F555UA-EH71 Battery Replacement, Battery: paso 5, imagen 2 de 3 ASUS F555UA-EH71 Battery Replacement, Battery: paso 5, imagen 3 de 3
    • Use the Phillips #000 screwdriver to remove the eight 4 mm screws holding the battery in place.
  6. ASUS F555UA-EH71 Battery Replacement: paso 6, imagen 1 de 2 ASUS F555UA-EH71 Battery Replacement: paso 6, imagen 2 de 2
    • Carefully remove the battery from the device.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 934
