Saltar al contenido principal
ASUS F550 Wifi Card Replacement
Qué necesitas
  1. ASUS F550 Wifi Card Replacement, ASUS F550 HDD/Ram Cover Removal: paso 1, imagen 1 de 2 ASUS F550 Wifi Card Replacement, ASUS F550 HDD/Ram Cover Removal: paso 1, imagen 2 de 2
    • Remove the battery, using release clips.
    • Ensure device has no residual power by attempting boot once battery is removed.
    • Remove either 2 (or 4 for a full teardown) 12mm phillips screws, then removing the bottom cover to gain access to the HDD and RAM.
    • Remove HDD and RAM cover
  2. ASUS F550 Wifi Card Replacement, HDD: paso 2, imagen 1 de 1
    • Remove 3 5mm Phillips screws
    • Slide HDD caddy back, remove using the black pull tab.
  3. ASUS F550 Wifi Card Replacement, HDD Removal from Caddy: paso 3, imagen 1 de 1
    • Remove 4 Phillips screws, 2 per side
    • Remove HDD from caddy.
  4. ASUS F550 Wifi Card Replacement, Keyboard: paso 4, imagen 1 de 1
    • Remove 7 5mm Phillips screws
  5. ASUS F550 Wifi Card Replacement: paso 5, imagen 1 de 3 ASUS F550 Wifi Card Replacement: paso 5, imagen 2 de 3 ASUS F550 Wifi Card Replacement: paso 5, imagen 3 de 3
    • Flip laptop and open lid. Separate the keyboard plate from the main housing, using a plastic prying tool. Being careful not to damage the LED indicators or other peripheries.
    • Disconnect the LED, trackpad, and keyboard ribbon cables.
    • The keyboard can now be removed
  6. ASUS F550 Wifi Card Replacement, Wifi Card: paso 6, imagen 1 de 2 ASUS F550 Wifi Card Replacement, Wifi Card: paso 6, imagen 2 de 2
    • Locate Wifi Card
    • Remove the antenna cables using a spudger tool.
    • Remove the Philips screw The Wifi Card will pop up and should be easily removed.
Conclusión
4 personas más completaron esta guía.
Ryan
Miembro Desde 08/19/15
1,414 Reputación
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 28
Todo El Tiempo: 6,538
