Saltar al contenido principal
ASUS Eee Pad Transformer Speakers Replacement
Qué necesitas
  1. ASUS Eee Pad Transformer Speakers Replacement, Back Panel: paso 1, imagen 1 de 2 ASUS Eee Pad Transformer Speakers Replacement, Back Panel: paso 1, imagen 2 de 2
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Eee Pad Transformer Speakers Replacement: paso 2, imagen 1 de 3 ASUS Eee Pad Transformer Speakers Replacement: paso 2, imagen 2 de 3 ASUS Eee Pad Transformer Speakers Replacement: paso 2, imagen 3 de 3
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer Speakers Replacement: paso 3, imagen 1 de 1
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer Speakers Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer Speakers Replacement: paso 5, imagen 1 de 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer Speakers Replacement: paso 6, imagen 1 de 2 ASUS Eee Pad Transformer Speakers Replacement: paso 6, imagen 2 de 2
    • Remove back panel by pulling away from the remaining device.
  7. ASUS Eee Pad Transformer Speakers Replacement, Speakers: paso 7, imagen 1 de 2 ASUS Eee Pad Transformer Speakers Replacement, Speakers: paso 7, imagen 2 de 2
    • Use the tweezers to grab onto the speaker and lift gently up until the speaker is removed.
    • Use your fingers to gently slide the speaker under the orange strip.
  8. ASUS Eee Pad Transformer Speakers Replacement: paso 8, imagen 1 de 2 ASUS Eee Pad Transformer Speakers Replacement: paso 8, imagen 2 de 2
    • Use the tweezers to disconnect the speakers from the motherboard.
  9. ASUS Eee Pad Transformer Speakers Replacement: paso 9, imagen 1 de 2 ASUS Eee Pad Transformer Speakers Replacement: paso 9, imagen 2 de 2
    • Use the tweezers to grab onto the speaker and gently lift it up until the speaker is removed from the device.
Conclusión
Una persona más ha completado esta guía.
Rillian Dennis
Miembro Desde 11/06/19
202 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G5, Harley Fall 2019 Miembro de IUPUI, Team S1-G5, Harley Fall 2019
IUPUI-HARLEY-F19S1G5
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 127
