Saltar al contenido principal
ASUS Eee Pad Transformer Buttons Replacement
Qué necesitas
  1. ASUS Eee Pad Transformer Buttons Replacement, Back Panel: paso 1, imagen 1 de 2 ASUS Eee Pad Transformer Buttons Replacement, Back Panel: paso 1, imagen 2 de 2
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Eee Pad Transformer Buttons Replacement: paso 2, imagen 1 de 3 ASUS Eee Pad Transformer Buttons Replacement: paso 2, imagen 2 de 3 ASUS Eee Pad Transformer Buttons Replacement: paso 2, imagen 3 de 3
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer Buttons Replacement: paso 3, imagen 1 de 1
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer Buttons Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer Buttons Replacement: paso 5, imagen 1 de 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer Buttons Replacement: paso 6, imagen 1 de 2 ASUS Eee Pad Transformer Buttons Replacement: paso 6, imagen 2 de 2
    • Remove back panel by pulling away from the remaining device.
  7. ASUS Eee Pad Transformer Buttons Replacement, Remove button screws: paso 7, imagen 1 de 2 ASUS Eee Pad Transformer Buttons Replacement, Remove button screws: paso 7, imagen 2 de 2
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the buttons to the back panel.
  8. ASUS Eee Pad Transformer Buttons Replacement, Locate and lift button clip: paso 8, imagen 1 de 3 ASUS Eee Pad Transformer Buttons Replacement, Locate and lift button clip: paso 8, imagen 2 de 3 ASUS Eee Pad Transformer Buttons Replacement, Locate and lift button clip: paso 8, imagen 3 de 3
    • Use Plastic Opening Tool to pry off the clip located towards the bottom of the button component near the metallic strip with a blue end, capped by the black button clip.
    • Remove button component by pulling straight outward from the device.
Conclusión
3 personas más completaron esta guía.
Joe Payne
Miembro Desde 09/29/14
534 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 13-9, Forte Fall 2014 Miembro de Cal Poly, Team 13-9, Forte Fall 2014
CPSU-FORTE-F14S13G9
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 26
Todo El Tiempo: 6,339
