Introducción
The keyboard on the ASUS Eee PC 1018P is an important component to the computer. While you may need to repair or replace the keyboard, you may also need to access the interior which can be done by removing the keyboard. In this tutorial you will learn how to remove the keyboard to repair or to access the internal components of the laptop.
Qué necesitas
Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
Herramienta utilizada en este paso:Tweezers$4.99
Remove the screws securing the bottom case to the keyboard.
Remove the six 3.68 mm screws and the single 4.45 mm screw that had been concealed by the battery.
Use a pair of tweezers to remove the two rubber covers located at the upper left and right corners.
With the rubber covers gone, two 4.52 mm screws should now be visible. Remove these screws.
Remove the black ribbon cable from the motherboard.
Use the tip of the plastic opening tool to push the black tabs on both sides of the white connector forward toward the display.
Pushing forward on one side will push the other side back toward the touch pad. Repeat the previous step until both black tabs will not move any farther.
Carefully pull the black ribbon cable horizontally toward the display until it slides free from the white motherboard connector. If it does not move when pulling on it, repeat previous steps until it does.
Una persona más ha completado esta guía.
