Saltar al contenido principal
ASUS EEE PC701SD-WHI004X Keyboard Replacement
Qué necesitas
  1. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Battery: paso 1, imagen 1 de 2 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the laptop over, you should see two battery tabs.
    • Slide the right tab towards the right. The orange dot should be visible. This tab will be locked open.
  2. ASUS EEE PC701SD-WHI004X Keyboard Replacement: paso 2, imagen 1 de 2 ASUS EEE PC701SD-WHI004X Keyboard Replacement: paso 2, imagen 2 de 2
    • While holding the left tab towards the left. Gently slide the battery out of the laptop.
  3. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: paso 3, imagen 1 de 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: paso 3, imagen 2 de 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: paso 3, imagen 3 de 3
    • Push the 3 tabs at the top of the keyboard in and down one at a time using a nylon spudger.
    • Once the three tabs have been pushed in, gently pry the top of the keyboard until it begins to hinge out of its slot.
    • The keyboard is still attached by a cable. Be careful when removing not to damage the cable. Do not yank the keyboard out.
  4. ASUS EEE PC701SD-WHI004X Keyboard Replacement: paso 4, imagen 1 de 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement: paso 4, imagen 2 de 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement: paso 4, imagen 3 de 3
    • Push the two sides of the ribbon cable connector away from yourself. This will unseat the ribbon cable.
    • Once the tabs are unseated, you can gently remove the ribbon cable by pulling it out of its slot. The keyboard can now be removed.
    • To be on the safe side, it’s better to use a nylon spudger, rather than the metal spudger shown in the picture.
Conclusión
Una persona más ha completado esta guía.
mir
Miembro Desde 03/24/17
409 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 505
