Saltar al contenido principal
ASUS E210MA-TB.CL464BK Wi-Fi Card Replacement
Qué necesitas
  1. ASUS E210MA-TB.CL464BK Wi-Fi Card Replacement, Wi-Fi Card: paso 1, imagen 1 de 3 ASUS E210MA-TB.CL464BK Wi-Fi Card Replacement, Wi-Fi Card: paso 1, imagen 2 de 3 ASUS E210MA-TB.CL464BK Wi-Fi Card Replacement, Wi-Fi Card: paso 1, imagen 3 de 3
    • Place the laptop with the bottom side facing up. Have the front (where the touchpad is) facing toward you.
    • Start by removing the ten 7mm screws on the bottom of the laptop using a JIS #00 screwdriver.
  2. ASUS E210MA-TB.CL464BK Wi-Fi Card Replacement: paso 2, imagen 1 de 1
    • Double-check to make sure all of the screws are removed.
    • If you have a Jimmy or other flat, straight-edge object, slide it in the crack where the halves of the case meet.
    • When the parts are separated, pull them apart to expose the insides of the case.
  3. ASUS E210MA-TB.CL464BK Wi-Fi Card Replacement: paso 3, imagen 1 de 2 ASUS E210MA-TB.CL464BK Wi-Fi Card Replacement: paso 3, imagen 2 de 2
    • Locate the card and remove it by gently lifting it up and pulling it out.
Conclusión
John Hutchins
Miembro Desde 02/07/23
763 Reputación
5 Guías creadas
Equipo
Gateway, Team 73-6, Gonzalez Spring 2023 Miembro de Gateway, Team 73-6, Gonzalez Spring 2023
GCC-GONZALEZ-S23S73G6
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 207
