Saltar al contenido principal
ASUS E210MA-TB.CL464BK Touchpad Replacement
Qué necesitas
  1. ASUS E210MA-TB.CL464BK Touchpad Replacement, Touchpad: paso 1, imagen 1 de 3 ASUS E210MA-TB.CL464BK Touchpad Replacement, Touchpad: paso 1, imagen 2 de 3 ASUS E210MA-TB.CL464BK Touchpad Replacement, Touchpad: paso 1, imagen 3 de 3
    • Place the laptop with the bottom side facing up. Have the front (where the touchpad is) facing toward you.
    • Start by removing the ten 7mm screws on the bottom of the laptop using a JIS #00 screwdriver.
  2. ASUS E210MA-TB.CL464BK Touchpad Replacement: paso 2, imagen 1 de 1
    • Double-check to make sure all of the screws are removed.
    • If you have a Jimmy or other flat, straight-edge object, slide it in the crack where the halves of the case meet.
    • When the parts are separated, pull them apart to expose the insides of the case.
  3. ASUS E210MA-TB.CL464BK Touchpad Replacement: paso 3, imagen 1 de 3 ASUS E210MA-TB.CL464BK Touchpad Replacement: paso 3, imagen 2 de 3 ASUS E210MA-TB.CL464BK Touchpad Replacement: paso 3, imagen 3 de 3
    • Remove the speakers as outlined in the speaker replacement guide, summarized below.
    • Remove the four 5mm screws, with a J00 screw driver.
    • Locate and remove the white plug by pulling it towards you.
  4. ASUS E210MA-TB.CL464BK Touchpad Replacement: paso 4, imagen 1 de 2 ASUS E210MA-TB.CL464BK Touchpad Replacement: paso 4, imagen 2 de 2
    • Remove the usb port as outlined in the usb port replacement guide, summarized below.
    • Remove the four 5mm screws with a J00 screwdriver.
    • You do not *need* to fully unplug and remove the USB port, but at least it is out of the way.
  5. ASUS E210MA-TB.CL464BK Touchpad Replacement: paso 5, imagen 1 de 3 ASUS E210MA-TB.CL464BK Touchpad Replacement: paso 5, imagen 2 de 3 ASUS E210MA-TB.CL464BK Touchpad Replacement: paso 5, imagen 3 de 3
    • Remove the battery as described in the battery replacement guide, summarized below.
    • Remove the five 5mm screws securing the battery with a J00 screwdriver.
    • Unplug and disconnect the tape.
  6. ASUS E210MA-TB.CL464BK Touchpad Replacement: paso 6, imagen 1 de 2 ASUS E210MA-TB.CL464BK Touchpad Replacement: paso 6, imagen 2 de 2
    • Identify the touchpad at the front of the case.
    • Unplug and remove the tape from the top of the touchpad.
  7. ASUS E210MA-TB.CL464BK Touchpad Replacement: paso 7, imagen 1 de 2 ASUS E210MA-TB.CL464BK Touchpad Replacement: paso 7, imagen 2 de 2
    • Remove the three 5mm screws from the top of the touchpad with a J00 screwdriver.
  8. ASUS E210MA-TB.CL464BK Touchpad Replacement: paso 8, imagen 1 de 2 ASUS E210MA-TB.CL464BK Touchpad Replacement: paso 8, imagen 2 de 2
    • Slide out the touchpad from under the metal bracket.pinching the top and sliding it forward and up.
Conclusión
John Hutchins
Miembro Desde 02/07/23
763 Reputación
5 Guías creadas
Equipo
Gateway, Team 73-6, Gonzalez Spring 2023 Miembro de Gateway, Team 73-6, Gonzalez Spring 2023
GCC-GONZALEZ-S23S73G6
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 192
