Introducción
The Power Buttons serves as the primary interface to boot up your computer. This guide will give you a step-by-step procedure on how to replace your Power Button in the case that it goes bad.
Qué necesitas
Use a Philips #1 screwdriver to remove the nine screws from the back cover.
Lay the keyboard with the key-side down. The circuit for the Power Button is just beneath the location of the button.
Unscrew the 2 screws holding the circuit in place, using the Philips #1 Screwdriver.
