Saltar al contenido principal
ASUS Chromebook C424MA-DH48F Speakers Replacement
Qué necesitas
  1. ASUS Chromebook C424MA-DH48F Speakers Replacement, Lower Case: paso 1, imagen 1 de 2 ASUS Chromebook C424MA-DH48F Speakers Replacement, Lower Case: paso 1, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the eleven 6.9 mm screws that secure the lower case.
    • Make sure all the screws on this side get taken out because there could be a label or warranty sticker covering up a screw that might be missed.
    • Insert an opening pick into the gap between the lower case and chassis.
    • Slide the pick around the entire perimeter of the laptop until the lower case fully releases.
    • Remove the lower case.
  2. ASUS Chromebook C424MA-DH48F Speakers Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: paso 2, imagen 1 de 3 ASUS Chromebook C424MA-DH48F Speakers Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: paso 2, imagen 2 de 3 ASUS Chromebook C424MA-DH48F Speakers Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: paso 2, imagen 3 de 3
    • Use an opening tool to pop up the silver locking bar securing the battery connector.
    • Push the battery connector directly out of its motherboard port.
  3. ASUS Chromebook C424MA-DH48F Speakers Replacement, Speakers: paso 3, imagen 1 de 3 ASUS Chromebook C424MA-DH48F Speakers Replacement, Speakers: paso 3, imagen 2 de 3 ASUS Chromebook C424MA-DH48F Speakers Replacement, Speakers: paso 3, imagen 3 de 3
    • Use an opening tool or your fingernails to gently "walk" the speaker connector directly out of its motherboard socket.
  4. ASUS Chromebook C424MA-DH48F Speakers Replacement: paso 4, imagen 1 de 1
    • Lift the right speaker up and out of the chassis, with care not to strain the connected cable.
  5. ASUS Chromebook C424MA-DH48F Speakers Replacement: paso 5, imagen 1 de 1
    • Unseat the speaker wires from the lower side of the battery.
  6. ASUS Chromebook C424MA-DH48F Speakers Replacement: paso 6, imagen 1 de 1
    • Lift the left speaker up and out of the chassis.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 23
