Saltar al contenido principal
ASUS Chromebook C300MA-DH01 Motherboard Replacement
Qué necesitas
  1. ASUS Chromebook C300MA-DH01 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Flip the Chromebook over so the bottom of the device is facing up.
  2. ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 2, imagen 1 de 2 ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 2, imagen 2 de 2
    • Using the JIS J0 Screwdriver, remove the following screws from the bottom:
    • (5) Five 6mm screws
    • (6) Six 8mm screws
  3. ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 3, imagen 1 de 3 ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 3, imagen 2 de 3 ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 3, imagen 3 de 3
    • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
  4. ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 4, imagen 1 de 3 ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 4, imagen 2 de 3 ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 4, imagen 3 de 3
    • Gently detach connecting cables.
    • Carefully flip up the large black tab.
    • Carefully flip up the small white tab.
    • Remove its corresponding black cable.
    • Remove its corresponding white cable.
    • The keyboard will be fully detached at this point. Set it aside for now.
  5. ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 5, imagen 1 de 1
    • Using the JIS J0 Screwdriver, unscrew and remove the (6) six 6mm screws from the device.
  6. ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 6, imagen 1 de 1
    • Using the plastic opening tool, gently push the connector tab away from the battery to detach the cable.
    • The battery will be fully detached at this point. Carefully lift it out of the device.
  7. ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 7, imagen 1 de 1
    • Using the plastic opening tool, disconnect the audio connection by pushing the audio tab toward the speakers.
    • With the audio cable detached, carefully lift the speakers out of the device.
  8. ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove the LCD cable from the motherboard.
    • Peel back the tape and then gently pull back on the connector cable.
  9. ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 9, imagen 1 de 1
    • Using the JIS J0 screwdriver, unscrew the 3mm screw.
    • Remove the Wi-Fi card from the motherboard.
  10. ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 10, imagen 1 de 1
    • Using the plastic opening tool, lift up on data cable for the daughterboard to remove it from the device.
  11. ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 11, imagen 1 de 2 ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 11, imagen 2 de 2
    • Using the JIS J0 Screwdriver unscrew and remove the (2) two 3 mm screws from the heat shield.
    • Gently lift up on the heat shield to remove it.
  12. ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 12, imagen 1 de 1
    • Using the JIS J0 Screwdriver, unscrew and remove the (3) three 6mm screws from the left hinge.
  13. ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 13, imagen 1 de 2 ASUS Chromebook C300MA-DH01 Motherboard Replacement: paso 13, imagen 2 de 2
    • Using the JIS J0 Screwdriver, unscrew and removing the following:
    • (1) One 3mm screw from the right side of the motherboard.
    • (1) One 4mm silver screw from the left side of the motherboard.
    • The motherboard can now be carefully removed from the device.
Conclusión
Gina Altimari
Miembro Desde 09/28/17
401 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S2-G5, Passmore Fall 2017 Miembro de USF Tampa, Team S2-G5, Passmore Fall 2017
USFT-PASSMORE-F17S2G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 202
