Saltar al contenido principal
ASUS Chromebook C200MA DS01 Wireless Card Replacement
Qué necesitas
  1. ASUS Chromebook C200MA DS01 Wireless Card Replacement, Back Panel: paso 1, imagen 1 de 1
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Wireless Card Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Wireless Card Replacement: paso 3, imagen 1 de 1
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Wireless Card Replacement, Battery Connection: paso 4, imagen 1 de 3 ASUS Chromebook C200MA DS01 Wireless Card Replacement, Battery Connection: paso 4, imagen 2 de 3 ASUS Chromebook C200MA DS01 Wireless Card Replacement, Battery Connection: paso 4, imagen 3 de 3
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Wireless Card Replacement, Wireless Card: paso 5, imagen 1 de 1
    • Remove the silver 2.8 mm Phillips #0 screw from the wireless card.
  6. ASUS Chromebook C200MA DS01 Wireless Card Replacement: paso 6, imagen 1 de 1
    • Use a spudger to disconnect the white and black antenna cables connected to the wireless card.
  7. ASUS Chromebook C200MA DS01 Wireless Card Replacement: paso 7, imagen 1 de 2 ASUS Chromebook C200MA DS01 Wireless Card Replacement: paso 7, imagen 2 de 2
    • Grab the wireless card between your thumb and index finger and pull directly away from the motherboard.
Conclusión
Christopher Lim
Miembro Desde 04/26/17
779 Reputación
7 Guías creadas
Equipo
Cal Poly, Team S23-G4, Livingston Spring 2017 Miembro de Cal Poly, Team S23-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G4
4 Miembros
19 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 763
