Saltar al contenido principal
ASUS Chromebook C200MA DS01 Touchpad Replacement
Qué necesitas
  1. ASUS Chromebook C200MA DS01 Touchpad Replacement, Back Panel: paso 1, imagen 1 de 1
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Touchpad Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Touchpad Replacement: paso 3, imagen 1 de 1
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: paso 4, imagen 1 de 3 ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: paso 4, imagen 2 de 3 ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: paso 4, imagen 3 de 3
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery: paso 5, imagen 1 de 2 ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery: paso 5, imagen 2 de 2
    • Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
  6. ASUS Chromebook C200MA DS01 Touchpad Replacement: paso 6, imagen 1 de 1
    • Pull out the battery.
  7. ASUS Chromebook C200MA DS01 Touchpad Replacement, Touchpad: paso 7, imagen 1 de 1
    • Locate the touchpad.
    • Locate the touch pad cable connector.
  8. ASUS Chromebook C200MA DS01 Touchpad Replacement: paso 8, imagen 1 de 3 ASUS Chromebook C200MA DS01 Touchpad Replacement: paso 8, imagen 2 de 3 ASUS Chromebook C200MA DS01 Touchpad Replacement: paso 8, imagen 3 de 3
    • Disconnect the touch pad ZIF(zero insertion force) connector.
    • Flip the flap up using a spudger or your fingers.
    • Pull gently on the ribbon cable to disconnect.
  9. ASUS Chromebook C200MA DS01 Touchpad Replacement: paso 9, imagen 1 de 1
    • Gently remove the adhesive on the touch pad ribbon cable.
  10. ASUS Chromebook C200MA DS01 Touchpad Replacement: paso 10, imagen 1 de 3 ASUS Chromebook C200MA DS01 Touchpad Replacement: paso 10, imagen 2 de 3 ASUS Chromebook C200MA DS01 Touchpad Replacement: paso 10, imagen 3 de 3
    • Gently remove the metallic tape from the touch pad only.
    • Try not to tear the tape, it can be re-used during reassembly.
  11. ASUS Chromebook C200MA DS01 Touchpad Replacement: paso 11, imagen 1 de 1
    • Remove the three 1.8 mm Phillips #00 screws.
  12. ASUS Chromebook C200MA DS01 Touchpad Replacement: paso 12, imagen 1 de 2 ASUS Chromebook C200MA DS01 Touchpad Replacement: paso 12, imagen 2 de 2
    • Lift the far edge of the touch pad to remove it.
Conclusión
Christopher Lim
Miembro Desde 04/26/17
779 Reputación
7 Guías creadas
Equipo
Cal Poly, Team S23-G4, Livingston Spring 2017 Miembro de Cal Poly, Team S23-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G4
4 Miembros
19 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 563
