Saltar al contenido principal
ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement
Qué necesitas
  1. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement, Lower Case: paso 1, imagen 1 de 1
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: paso 2, imagen 1 de 1
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use the T5 screwdriver to remove the six 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: paso 4, imagen 1 de 1
    • Use the iFixit opening tool to remove the back of the laptop.
  5. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: paso 5, imagen 1 de 1
    • Use the blunt nose tweezers to separate the keyboard from the internal components.
  6. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement, Trackpad: paso 6, imagen 1 de 2 ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement, Trackpad: paso 6, imagen 2 de 2
    • Grip the keyboard and carefully pull it off the device.
  7. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: paso 7, imagen 1 de 2 ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: paso 7, imagen 2 de 2
    • On the back of the keyboard assembly, use the tweezers to pull the white cable from the track pad.
  8. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: paso 8, imagen 1 de 1
    • Remove the three 1 mm screws from the track pad using the JIS 00 screwdriver.
  9. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: paso 9, imagen 1 de 2 ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: paso 9, imagen 2 de 2
    • Grip the track pad with the tweezers and slide it up and out of the keyboard assembly.
Conclusión
Lauren Schirle
Miembro Desde 01/24/19
205 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S19-G4, White Winter 2019 Miembro de Cal Poly, Team S19-G4, White Winter 2019
CPSU-WHITE-W19S19G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 372
