Saltar al contenido principal
ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement
Qué necesitas
  1. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement, Lower Case: paso 1, imagen 1 de 1
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement: paso 2, imagen 1 de 1
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement: paso 3, imagen 1 de 1
    • Use the T5 screwdriver to remove the six 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement: paso 4, imagen 1 de 1
    • Use the iFixit opening tool to remove the back of the laptop.
  5. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement: paso 5, imagen 1 de 1
    • Use the blunt nose tweezers to separate the keyboard from the internal components.
  6. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement, Keyboard: paso 6, imagen 1 de 2 ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement, Keyboard: paso 6, imagen 2 de 2
    • Remove the keyboard from the laptop.
    • The Trackpad is attached to the keyboard assembly. The Trackpad replacement guide can be found on the ASUS Chromebook CPPA-RBRKT07 homepage.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team S19-G4, White Winter 2019 Miembro de Cal Poly, Team S19-G4, White Winter 2019
CPSU-WHITE-W19S19G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 453
