Saltar al contenido principal
ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement
Qué necesitas
  1. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement, Lower Case: paso 1, imagen 1 de 1
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: paso 2, imagen 1 de 1
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: paso 3, imagen 1 de 1
    • Use the T5 screwdriver to remove the six 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: paso 4, imagen 1 de 1
    • Use the iFixit opening tool to remove the back of the laptop.
  5. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: paso 5, imagen 1 de 1
    • Use the blunt nose tweezers to separate the keyboard from the internal components.
  6. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement, Audio Ports: paso 6, imagen 1 de 1
    • Remove the four 3mm J1 screws attached to the audio cards.
  7. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: paso 7, imagen 1 de 2 ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: paso 7, imagen 2 de 2
    • Lift and remove the audio cards.
    • Separate the wires from the motherboard.
Conclusión
Tomas Martinez
Miembro Desde 01/24/19
185 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S19-G4, White Winter 2019 Miembro de Cal Poly, Team S19-G4, White Winter 2019
CPSU-WHITE-W19S19G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 131
