Saltar al contenido principal
APS Tech 101629 Exhaust Fan Replacement
Qué necesitas
  1. APS Tech 101629 Exhaust Fan Replacement, External Casing: paso 1, imagen 1 de 3 APS Tech 101629 Exhaust Fan Replacement, External Casing: paso 1, imagen 2 de 3 APS Tech 101629 Exhaust Fan Replacement, External Casing: paso 1, imagen 3 de 3
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 Exhaust Fan Replacement: paso 2, imagen 1 de 2 APS Tech 101629 Exhaust Fan Replacement: paso 2, imagen 2 de 2
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 Exhaust Fan Replacement: paso 3, imagen 1 de 2 APS Tech 101629 Exhaust Fan Replacement: paso 3, imagen 2 de 2
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 Exhaust Fan Replacement: paso 4, imagen 1 de 1
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 Exhaust Fan Replacement: paso 5, imagen 1 de 2 APS Tech 101629 Exhaust Fan Replacement: paso 5, imagen 2 de 2
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 Exhaust Fan Replacement, Channel Switch: paso 6, imagen 1 de 2 APS Tech 101629 Exhaust Fan Replacement, Channel Switch: paso 6, imagen 2 de 2
    • Find the conjoined ID cable wires that are colored black, orange, and yellow.
    • Lift white portion of cable wires to disconnect it.
  7. APS Tech 101629 Exhaust Fan Replacement: paso 7, imagen 1 de 3 APS Tech 101629 Exhaust Fan Replacement: paso 7, imagen 2 de 3 APS Tech 101629 Exhaust Fan Replacement: paso 7, imagen 3 de 3
    • At this point, the fan is loose and can be easily moved but not disconnected.
    • Using the spudger, depress the pressure holders at all four corners of the fan.
    • Take out the fan and its cords, by pulling it outward from its cavity within the device.
  8. APS Tech 101629 Exhaust Fan Replacement, Power Switch: paso 8, imagen 1 de 2 APS Tech 101629 Exhaust Fan Replacement, Power Switch: paso 8, imagen 2 de 2
    • Depress 2 pressure holds on each side of the power switch.
    • Press out the back of the device.
  9. APS Tech 101629 Exhaust Fan Replacement: paso 9, imagen 1 de 2 APS Tech 101629 Exhaust Fan Replacement: paso 9, imagen 2 de 2
    • Remove all four 4 connections from the power switch.
    • Remember that the straight connections are on the far side, while the L-shaped connections are on the near side, and that both yellow connections are on top. This is helpful for reassembly.
    • These are very hard to get off, use patience and wiggling.
  10. APS Tech 101629 Exhaust Fan Replacement, Exhaust Fan: paso 10, imagen 1 de 1
    • Remove temperature guage.
  11. APS Tech 101629 Exhaust Fan Replacement: paso 11, imagen 1 de 3 APS Tech 101629 Exhaust Fan Replacement: paso 11, imagen 2 de 3 APS Tech 101629 Exhaust Fan Replacement: paso 11, imagen 3 de 3
    • Move the exhaust fan out of the way so you can access its control cord.
    • Use the spudger to depress the hold on the fan cord.
    • Gently pull fan cord from connection and remove fan completely.
Conclusión
Patrick Meyer
Miembro Desde 04/10/11
83 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 24-60, Amido Spring 2011 Miembro de Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 685
