Saltar al contenido principal
APEX TM785CH Speakers Replacement
Qué necesitas
  1. APEX TM785CH Speakers Replacement, Back Casing: paso 1, imagen 1 de 2 APEX TM785CH Speakers Replacement, Back Casing: paso 1, imagen 2 de 2
    • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
    • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
    • Move along the top edge of the tablet and repeat the step above.
    • Pull the back cover away from the tablet body to completely remove it.
  2. APEX TM785CH Speakers Replacement, Speakers: paso 2, imagen 1 de 3 APEX TM785CH Speakers Replacement, Speakers: paso 2, imagen 2 de 3 APEX TM785CH Speakers Replacement, Speakers: paso 2, imagen 3 de 3
    • The speakers are located towards the bottom left and bottom right corners of the tablet.
    • If not already done, remove the black tape holding the wires down.
    • Wedge a spudger underneath the speaker in its socket, near where the wires are connected. You can then pry out the speakers.
  3. APEX TM785CH Speakers Replacement: paso 3, imagen 1 de 2 APEX TM785CH Speakers Replacement: paso 3, imagen 2 de 2
    • You will need a soldering/desoldering kit to desolder the 4 leads where the speakers connect to the circuit board.
Conclusión
Equipo
Baylor, Team 4-1, Williams Spring 2015 Miembro de Baylor, Team 4-1, Williams Spring 2015
BU-WILLIAMS-S15S4G1
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 2,585
