Introducción
You will be able to break down the tablet to it's front camera and remove it.
Qué necesitas
Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
Wedge a plastic opening tool into the opening and push it down to force the back cover off.
Move along the top edge of the tablet and repeat the step above.
Pull the back cover away from the tablet body to completely remove it.
To get to the front camera, you will first need to remove the top panel.
Unscrew two 2.25 mm Phillips screws with a #00 screwdriver from the top plastic panel to remove it.
Herramienta utilizada en este paso:Tweezers$4.99
First, use plastic coated tweezers to pull up the black release tab.
Pull on the black connector with tweezers as close as possible to the white connector base, making sure not to pull on the connector base.
Next, use the tweezers to peel off the tape holding down the connector to the front camera.
The front camera can now be removed from its socket.
