Saltar al contenido principal
APEX AP-GS918 Power/Volume Button Replacement
Qué necesitas
  1. APEX AP-GS918 Power/Volume Button Replacement, Power/Volume Button: paso 1, imagen 1 de 3 APEX AP-GS918 Power/Volume Button Replacement, Power/Volume Button: paso 1, imagen 2 de 3 APEX AP-GS918 Power/Volume Button Replacement, Power/Volume Button: paso 1, imagen 3 de 3
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
  2. APEX AP-GS918 Power/Volume Button Replacement: paso 2, imagen 1 de 3 APEX AP-GS918 Power/Volume Button Replacement: paso 2, imagen 2 de 3 APEX AP-GS918 Power/Volume Button Replacement: paso 2, imagen 3 de 3
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
  3. APEX AP-GS918 Power/Volume Button Replacement: paso 3, imagen 1 de 2 APEX AP-GS918 Power/Volume Button Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
Conclusión
Equipo
USF Tampa, Team 9-1, Leahy Winter 2015 Miembro de USF Tampa, Team 9-1, Leahy Winter 2015
USFT-LEAHY-W15S9G1
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 226
