Saltar al contenido principal
AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement
Qué necesitas
  1. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: paso 1, imagen 1 de 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: paso 1, imagen 2 de 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: paso 1, imagen 3 de 3
    • Remove screws
    • Insert spudger tool on the middle of the left side, between the white and black plastic
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed
    • Pull off the back cover
  2. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: paso 2, imagen 1 de 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: paso 2, imagen 2 de 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: paso 2, imagen 3 de 3
    • Remove the broken volume rocker/power button unit.
    • Place the new part into the empty slot.
  3. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: paso 3, imagen 1 de 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: paso 3, imagen 2 de 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: paso 3, imagen 3 de 3
    • Gently press the speaker into place.
    • Replace the back cover with the new part in place.
    • Be careful to not let the volume rocker unit fall out of place.
    • Replace the screws.
Linea de Meta
2 personas más completaron esta guía.
Miles
Miembro Desde 03/24/15
260 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 506
