Saltar al contenido principal
AKASO KingPad A90 Rear Speaker Replacement
Qué necesitas
  1. AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: paso 1, imagen 1 de 3 AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: paso 1, imagen 2 de 3 AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: paso 1, imagen 3 de 3
    • Remove screws.
    • Insert spudger tool on the middle of the left side, between the white and black plastic.
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed.
    • Pull off the back cover.
  2. AKASO KingPad A90 Rear Speaker Replacement: paso 2, imagen 1 de 3 AKASO KingPad A90 Rear Speaker Replacement: paso 2, imagen 2 de 3 AKASO KingPad A90 Rear Speaker Replacement: paso 2, imagen 3 de 3
    • Plug in soldering iron and let it warm up for ten minutes.
    • Locate the speaker solder points and note where it is attached to the motherboard.
    • Solder the old speaker out of its mark. (Touch the tip of the solder iron to the soldering point).
  3. AKASO KingPad A90 Rear Speaker Replacement: paso 3, imagen 1 de 3 AKASO KingPad A90 Rear Speaker Replacement: paso 3, imagen 2 de 3 AKASO KingPad A90 Rear Speaker Replacement: paso 3, imagen 3 de 3
    • Solder the new speaker onto the points where the old speaker was.
  4. AKASO KingPad A90 Rear Speaker Replacement: paso 4, imagen 1 de 3 AKASO KingPad A90 Rear Speaker Replacement: paso 4, imagen 2 de 3 AKASO KingPad A90 Rear Speaker Replacement: paso 4, imagen 3 de 3
    • Replace the back cover with the new rear speaker unit in place.
    • Gently press the speaker into place.
    • Don't let the volume rocker unit fall out of place.
    • Replace the screws.
Linea de Meta
camchristo
Miembro Desde 03/24/15
71 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 380
