Saltar al contenido principal
AEG Electrolux FM72 Disassembly for cleaning
Qué necesitas
  1. AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: paso 1, imagen 1 de 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: paso 1, imagen 2 de 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: paso 1, imagen 3 de 3
    • Open the lid by pressing the grey button and lifting it away.
    • Clean each of the plastic parts with soap and water, and then leave them out to dry.
  2. AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: paso 2, imagen 1 de 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: paso 2, imagen 2 de 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: paso 2, imagen 3 de 3
    • Follow these steps to open the electronic casing.
    • Remove the four screws as shown in picture two.
    • A long Phillips screwdriver is needed for step two.
    • Remove the fifth screw at the bottom as shown in picture three.
  3. AEG Electrolux FM72 Disassembly for cleaning: paso 3, imagen 1 de 3 AEG Electrolux FM72 Disassembly for cleaning: paso 3, imagen 2 de 3 AEG Electrolux FM72 Disassembly for cleaning: paso 3, imagen 3 de 3
    • Gently pry the device open, using an iSesamo opener.
    • Now the I/O button can be removed.
    • Completely replacing this entire part requires desoldering wire connections.
  4. AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: paso 4, imagen 1 de 2 AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: paso 4, imagen 2 de 2
    • Now the electronic components can be cleaned using an air compressor.
    • In picture one, you can see the PCBs. Under the PCB, you'll see blue batteries. These are 2 x 3 AA rechargeable batteries .
    • If the dust bag needs to be replaced, remove its securing screws.
Conclusión
3 personas más completaron esta guía.
Kevin D
Miembro Desde 05/02/14
7,418 Reputación
21 Guías creadas
3 comentarios
Hello
How can i repair the electric wire on this device please ?
Heloise - Contestar
Hallo
Which electric wire do you mean? Can you send in a picture? Does it need soldering?
Kind regards
Kevin
Kevin D - Contestar
How can I disassemble the motor parts for cleaning?
wongkapo0611 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 13
Ultimos 30 días: 38
Todo El Tiempo: 6,950
