Introducción
This IFIXIT guide allows you to safely and properly remove the CAMERA from the AEE Mach 1 Drone. In order to remove the camera, please follow the step-by-step directions below and make sure to use the proper tools listed. When removing the top panel, make sure to be careful as there are still wired connections. Fix it!
Qué necesitas
Take out the AEE Mach 1 and place it on a surface with its propellers facing up.
Casi Terminas!
Conclusión
