Saltar al contenido principal
AEE Mach 1 Battery Replacement
  1. AEE Mach 1 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure that your device is powered off before doing any work.
    • The battery is located at the back of the drone, on the opposite end of the drone from the camera.
    • There are two tabs on the edge of each side of the battery.
  2. AEE Mach 1 Battery Replacement: paso 2, imagen 1 de 1
    • To remove the battery, simply grip the battery by the tabs, press down on both tabs, and pull the battery out.
  3. AEE Mach 1 Battery Replacement: paso 3, imagen 1 de 1
    • To replace the battery, simply slide it back into its place until the tabs click back into place. If you are having trouble doing this, you may be putting it in upside down. Try flipping it over and trying again.
Conclusión
Una persona más ha completado esta guía.
2 comentarios
purchase the aee mach 1 but it has no battery
Ulysses aka UL Salett - Contestar
How do I get a new battery where do I look
haroldlknight55 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 26
Todo El Tiempo: 635
