Saltar al contenido principal
ACN Iris WG4K Motherboard Replacement
Qué necesitas
  1. ACN Iris WG4K Motherboard Replacement, Handset: paso 1, imagen 1 de 2 ACN Iris WG4K Motherboard Replacement, Handset: paso 1, imagen 2 de 2
    • Press upwards with your index finger on the 4P4C connector as shown in the image.
    • Pull the connector gently out of its socket.
  2. ACN Iris WG4K Motherboard Replacement, Lower Case: paso 2, imagen 1 de 1
    • Flip the main body of the video phone so that the bottom is facing up.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
  3. ACN Iris WG4K Motherboard Replacement: paso 3, imagen 1 de 2 ACN Iris WG4K Motherboard Replacement: paso 3, imagen 2 de 2
    • Lift the back case upwards to expose the inside components.
    • Red rectangles indicate the three ribbon cables.
    • The orange square indicates the blade connector.
  4. ACN Iris WG4K Motherboard Replacement: paso 4, imagen 1 de 3 ACN Iris WG4K Motherboard Replacement: paso 4, imagen 2 de 3 ACN Iris WG4K Motherboard Replacement: paso 4, imagen 3 de 3
    • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull the ribbon cables out of their insulation-displacement connectors.
  5. ACN Iris WG4K Motherboard Replacement: paso 5, imagen 1 de 2 ACN Iris WG4K Motherboard Replacement: paso 5, imagen 2 de 2
    • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
    • Gently pull the blade connector out of the blade receptacle.
  6. ACN Iris WG4K Motherboard Replacement: paso 6, imagen 1 de 1
    • Gently lift up the lower case to separate it from the top case.
  7. ACN Iris WG4K Motherboard Replacement, Motherboard: paso 7, imagen 1 de 1
  8. ACN Iris WG4K Motherboard Replacement: paso 8, imagen 1 de 2 ACN Iris WG4K Motherboard Replacement: paso 8, imagen 2 de 2
    • Firmly grasp the black port wall.
    • Pull up and push out to remove it from the lower case.
  9. ACN Iris WG4K Motherboard Replacement: paso 9, imagen 1 de 1
    • Gently lift the motherboard out of the lower case.
Conclusión
Itze Kenney
Miembro Desde 02/14/17
1,066 Reputación
9 Guías creadas
Equipo
USF Tampa, Team 20-4, Remmell Spring 2017 Miembro de USF Tampa, Team 20-4, Remmell Spring 2017
USFT-REMMELL-S17S20G4
4 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 329
