Saltar al contenido principal
ACER Aspire V5-571P-6609 RAM Replacement
Qué necesitas
  1. ACER Aspire V5-571P-6609 RAM Replacement, RAM: paso 1, imagen 1 de 3 ACER Aspire V5-571P-6609 RAM Replacement, RAM: paso 1, imagen 2 de 3 ACER Aspire V5-571P-6609 RAM Replacement, RAM: paso 1, imagen 3 de 3
    • Make sure you completely power off the device before proceeding.
    • Turn over the device to display the back cover and remove the two marked Phillips #0 screws.
  2. ACER Aspire V5-571P-6609 RAM Replacement: paso 2, imagen 1 de 3 ACER Aspire V5-571P-6609 RAM Replacement: paso 2, imagen 2 de 3 ACER Aspire V5-571P-6609 RAM Replacement: paso 2, imagen 3 de 3
    • Once the screws have been removed, utilize a jimmy tool to pry open the back cover. Carefully lift the cover and set it aside for now.
  3. ACER Aspire V5-571P-6609 RAM Replacement: paso 3, imagen 1 de 3 ACER Aspire V5-571P-6609 RAM Replacement: paso 3, imagen 2 de 3 ACER Aspire V5-571P-6609 RAM Replacement: paso 3, imagen 3 de 3
    • With two fingers, push the latches holding the DIMM to the sides.
    • The DIMM will tilt upward once it is released from the slot.
    • Carefully secure the DIMM and remove it.
  4. ACER Aspire V5-571P-6609 RAM Replacement: paso 4, imagen 1 de 3 ACER Aspire V5-571P-6609 RAM Replacement: paso 4, imagen 2 de 3 ACER Aspire V5-571P-6609 RAM Replacement: paso 4, imagen 3 de 3
    • Repeat the same process from the previous step for the second slot.
  5. ACER Aspire V5-571P-6609 RAM Replacement: paso 5, imagen 1 de 2 ACER Aspire V5-571P-6609 RAM Replacement: paso 5, imagen 2 de 2
    • Insert the replacement DIMM into the slot.
    • Once inserted, push the DIMM down gently until it snaps into place.
  6. ACER Aspire V5-571P-6609 RAM Replacement: paso 6, imagen 1 de 3 ACER Aspire V5-571P-6609 RAM Replacement: paso 6, imagen 2 de 3 ACER Aspire V5-571P-6609 RAM Replacement: paso 6, imagen 3 de 3
    • Place the cover back on.
    • Insert the screws back into place with a screwdriver.
Conclusión
To reassemble your device, follow these instructions in reverse order with new RAM cards.
Ernesto Pacheco
Miembro Desde 10/25/22
277 Reputación
2 Guías creadas
Equipo
Gateway, Team 1-1, Pee Fall 2022 Miembro de Gateway, Team 1-1, Pee Fall 2022
GCC-PEE-F22S1G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 19
Todo El Tiempo: 143
