Introducción
Using this guide you will be able to replace or remove the RAM from your laptop.
Qué necesitas
Flip your laptop over so the back panel is facing upwards.
Locate the lock switch below the battery.
Unscrew the one 2.5 x 8mm Phillips #0 screw from the bottom panel as designated in the image.
Una persona más ha completado esta guía.
