Introducción
If you have a faulty battery on a ACER Aspire 7750G 6645 then this guide will help you remove the faulty battery and replace it with a working battery. Once this process is completed it is recommended that the laptop is plugged in for a couple of hours to allow the new battery to fully charge.
Qué necesitas
The battery is on the back of the device, on the underside of the laptop.
Push the switch over to unlock the battery. You may need a pen/spudger to push the lock.
Una persona más ha completado esta guía.
