Saltar al contenido principal
AARP RealPad MA7BX2 Back Cover Replacement
Qué necesitas
  1. AARP RealPad MA7BX2 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 2 AARP RealPad MA7BX2 Back Cover Replacement, Back Cover: paso 1, imagen 2 de 2
    • Loosen the back cover using the suction cup.
    • Pull up on the center of the back with the suction cup.
    • Pull up on all four corners of the back with the suction cup.
  2. AARP RealPad MA7BX2 Back Cover Replacement: paso 2, imagen 1 de 1
    • Remove the back cover by gently placing the small opening tool in the crevice created by loosening the back.
    • Slide the opening tool around the edges of the device.
    • Wedge it open using the opening tool.
    • Use the suction cup again if you're having trouble removing the back cover.
  3. AARP RealPad MA7BX2 Back Cover Replacement: paso 3, imagen 1 de 2 AARP RealPad MA7BX2 Back Cover Replacement: paso 3, imagen 2 de 2
    • The black tape is stuck to delicate wires; remove with caution.
    • Peel off the silver tape.
    • Gently pull off the black tape.
  4. AARP RealPad MA7BX2 Back Cover Replacement: paso 4, imagen 1 de 2 AARP RealPad MA7BX2 Back Cover Replacement: paso 4, imagen 2 de 2
    • Using a JIS #000 screwdriver, remove the two 2.5 mm screws.
  5. AARP RealPad MA7BX2 Back Cover Replacement: paso 5, imagen 1 de 2 AARP RealPad MA7BX2 Back Cover Replacement: paso 5, imagen 2 de 2
    • Lift off the black audio cover.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 834
