Saltar al contenido principal
A Jammed SD Card Tray
Qué necesitas
  1. A Jammed SD Card Tray, A Jammed SD Card Tray: paso 1, imagen 1 de 2 A Jammed SD Card Tray, A Jammed SD Card Tray: paso 1, imagen 2 de 2
    • As you see the sd tray is bent in.
    • And you can’t get it open like usual.
  2. A Jammed SD Card Tray, Popping up tray: paso 2, imagen 1 de 2 A Jammed SD Card Tray, Popping up tray: paso 2, imagen 2 de 2
    • Pop up the sd port tray
  3. A Jammed SD Card Tray, Popping open tray: paso 3, imagen 1 de 3 A Jammed SD Card Tray, Popping open tray: paso 3, imagen 2 de 3 A Jammed SD Card Tray, Popping open tray: paso 3, imagen 3 de 3
    • Here is the tool you need or something similar
    • PLEASE BE CAREFUL IT CAN DAMAGE THE EXPOSED MOTHERBOARD INSIDE IF NOT
  4. A Jammed SD Card Tray, Remove sd card: paso 4, imagen 1 de 3 A Jammed SD Card Tray, Remove sd card: paso 4, imagen 2 de 3 A Jammed SD Card Tray, Remove sd card: paso 4, imagen 3 de 3
    • You have to press down on sd like the physical game to get it out
    • And don’t forget to close the tray
Conclusión
Thanks and you’re welcome now you have free access to your sd card!
Sqwerks
Miembro Desde 10/31/22
512 Reputación
1 Guía escrita
Equipo
Oregonians Miembro de Oregonians
Community
7 Miembros
176 Guías creadas
4 comentarios
My first guide 😂
Sqwerks - Contestar
its been officially accepted as of two months ago yahoo
Sqwerks - Contestar
also i sold the 3ds to @tronicsfix (if your reading this sorry) but yea (just so you know I'm here as well)
Sqwerks - Contestar
it was by wild chance even though they are my main inspiration and got me into ifixit
Sqwerks - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 58
Todo El Tiempo: 713
