Saltar al contenido principal
8BitDo Ultimate Wired Vibration/Rumble Motor Replacement
Qué necesitas
  1. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement, Vibration/Rumble Motor: paso 1, imagen 1 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement, Vibration/Rumble Motor: paso 1, imagen 2 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement, Vibration/Rumble Motor: paso 1, imagen 3 de 3
    • Orient the controller such that the back of the controller is facing you.
    • Insert an opening tool into the small opening on the back of the grip, and gently pry the grip cover away until it pops free.
  2. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 2, imagen 1 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 2, imagen 2 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 2, imagen 3 de 3
    • Pry the other grip panel off using the same method.
  3. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 3, imagen 1 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 3, imagen 2 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 3, imagen 3 de 3
    • Use the TR6 Torx Security screwdriver to remove the top left 10.44 mm screw on the backside.
    • Use tweezers to help you remove the screw if it does not come out with the driver.
  4. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 4, imagen 1 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 4, imagen 2 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 4, imagen 3 de 3
    • Use the TR6 Torx Security screwdriver to remove the middle left 10.44 mm Torx screw on the backside.
  5. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 5, imagen 1 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 5, imagen 2 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 5, imagen 3 de 3
    • Use the TR6 Torx Security screwdriver to remove the bottom left 10.44 mm Torx screw on the backside.
  6. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 6, imagen 1 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 6, imagen 2 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 6, imagen 3 de 3
    • Use the TR6 Torx Security screwdriver to remove the top right 10.44 mm Torx screw on the backside.
  7. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 7, imagen 1 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 7, imagen 2 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 7, imagen 3 de 3
    • Use the TR6 Torx Security screwdriver to remove the middle right 10.44 mm Torx screw on the backside.
  8. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 8, imagen 1 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 8, imagen 2 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 8, imagen 3 de 3
    • Use the TR6 Torx Security screwdriver to unscrew the bottom right 10.44 mm Torx screw on the backside.
  9. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 9, imagen 1 de 2 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 9, imagen 2 de 2
    • Insert an opening tool into the small opening between the front and back panels, and gently pry the back panel away to open the bottom clamps of the top panel of the controller.
  10. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 10, imagen 1 de 2 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 10, imagen 2 de 2
    • Insert an opening tool into the small opening between the front and back panel (top view) and pry away to remove the top half.
    • A ribbon cable connects the front and back portions of the controller.
  11. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 11, imagen 1 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 11, imagen 2 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 11, imagen 3 de 3
    • Pull the midframe free with an adequate amount of force.
  12. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 12, imagen 1 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 12, imagen 2 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 12, imagen 3 de 3
    • Detach the motor connector from the motherboard.
  13. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 13, imagen 1 de 2 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 13, imagen 2 de 2
    • Pull the weight out of the housing with adequate force.
  14. 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 14, imagen 1 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 14, imagen 2 de 3 8BitDo Ultimate Wired Vibration/Rumble Motor Replacement: paso 14, imagen 3 de 3
    • Remove the rumble or vibration motor from the controller.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 39
Todo El Tiempo: 365
