Saltar al contenido principal
8BitDo SN30 Pro+ Controller Buttons Replacement
Qué necesitas
  1. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Battery: paso 1, imagen 1 de 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Battery: paso 1, imagen 2 de 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Battery: paso 1, imagen 3 de 3
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Trigger Buttons: paso 2, imagen 1 de 2 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Trigger Buttons: paso 2, imagen 2 de 2
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: paso 3, imagen 1 de 2 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. 8BitDo SN30 Pro+ Controller Buttons Replacement, Unclip Covers: paso 4, imagen 1 de 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Unclip Covers: paso 4, imagen 2 de 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Unclip Covers: paso 4, imagen 3 de 3
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. 8BitDo SN30 Pro+ Controller Buttons Replacement, Separate Covers: paso 5, imagen 1 de 1
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Ribbon Cable: paso 6, imagen 1 de 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Ribbon Cable: paso 6, imagen 2 de 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Ribbon Cable: paso 6, imagen 3 de 3
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
  7. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: paso 7, imagen 1 de 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: paso 7, imagen 2 de 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: paso 7, imagen 3 de 3
    • Use a Phillips screwdriver to remove the seven screws securing the main circuit board.
    • Six 10.1mm screws
    • One 5.8mm screws
  8. 8BitDo SN30 Pro+ Controller Buttons Replacement, Separate Main Board: paso 8, imagen 1 de 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Separate Main Board: paso 8, imagen 2 de 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Separate Main Board: paso 8, imagen 3 de 3
    • Slide the R buttons up and off its peg.
    • Slide the L button up and off its peg.
    • Remove the main board by rotating it towards the USB-C port. Then lift it out.
  9. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Rubber Pads: paso 9, imagen 1 de 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Rubber Pads: paso 9, imagen 2 de 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Rubber Pads: paso 9, imagen 3 de 3
    • Use a pair of tweezers or your fingers to remove the five silicone rubber pads.
    • Three black conductive pads.
    • Two clear pads.
    • During reassembly, make sure AXBY conductive rubber has the cut out on the top.
  10. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Buttons: paso 10, imagen 1 de 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Buttons: paso 10, imagen 2 de 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Buttons: paso 10, imagen 3 de 3
    • Use a pair of tweezers or your fingers to remove the buttons you wish to replace.
    • The Home button is two parts: the center button and the outer clear ring.
Conclusión
9 personas más completaron esta guía.
Brian W
Miembro Desde 12/21/11
1,773 Reputación
8 Guías creadas
4Guía Comentarios
Hi, it looks like the buttons have little notches that limit where they can go. I was really hoping to modify it so that my a button is green and my b is red would that work if I file down that little notch?
Will Platt - Contestar
The buttons are all the same height, so feel free to file down. Those nubs are just part of assemble process.
But do leave the 2 longer stems on each side of the button, they stop it from rotating freely.
Brian W -
I just completed this guide, and it is 100% perfection. The photos are useful and clear, and explanations are on point. Many thanks.
Chris Zirker - Contestar
I especially appreciate mention of screw length as I'm prone to mixing them up. Lovely guide 🫠
Joshua Napier - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 32
Ultimos 30 días: 138
Todo El Tiempo: 10,326
