Saltar al contenido principal
8BitDo NES30 Pro Gamepad Button Replacement
Qué necesitas
  1. 8BitDo NES30 Pro Gamepad Button Replacement, Button: paso 1, imagen 1 de 2 8BitDo NES30 Pro Gamepad Button Replacement, Button: paso 1, imagen 2 de 2
    • Hold the controller with its back facing towards you.
    • Insert an opening pick between the L1 or R1 button and the backplate, and pry the backplate off of the controller.
  2. 8BitDo NES30 Pro Gamepad Button Replacement: paso 2, imagen 1 de 2 8BitDo NES30 Pro Gamepad Button Replacement: paso 2, imagen 2 de 2
    • Place the controller face down on a solid surface.
    • Remove the seven screws with the Phillips #00 screwdriver.
  3. 8BitDo NES30 Pro Gamepad Button Replacement: paso 3, imagen 1 de 1
    • Lift the body of the controller up and away from the controller's face and buttons.
  4. 8BitDo NES30 Pro Gamepad Button Replacement: paso 4, imagen 1 de 2 8BitDo NES30 Pro Gamepad Button Replacement: paso 4, imagen 2 de 2
    • Lift away the black rubber pads that sit between the face buttons and body of the controller.
  5. 8BitDo NES30 Pro Gamepad Button Replacement: paso 5, imagen 1 de 1
    • Lift the buttons out of the face of the controller.
  6. 8BitDo NES30 Pro Gamepad Button Replacement: paso 6, imagen 1 de 2 8BitDo NES30 Pro Gamepad Button Replacement: paso 6, imagen 2 de 2
    • Align the notches of the face buttons to put them back into place.
    • Each button has a unique notch pattern so it can't be replaced incorrectly.
    • Attach the rubber pads by placing their smaller and larger holes around the matching size pegs.
Conclusión
Una persona más ha completado esta guía.
2 comentarios
Hello there, any idea where I can find those black rubber pads for replacement ? mine is torn.
Thx
Ben Kakita - Contestar
sorry, i try to search every where, have a tone for other controller, even have for 8bitdo snes, but not for nes 30 pro.
if you find it, answer on that chat. Good luck
Freeman loran - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 44
Todo El Tiempo: 1,841
