Introducción
Printed parts needed:
1x X Carriage Wire Tube Holder.stl
1x X carriage shield for the metal kit.stl
One of the following:
1x Metal kit - BLtouch adapter.stl
1x BLTouch Front Mount Adapter.stl
Qué necesitas
Using 2x M3x8 socket head screws mount the V6 Front Plate Mount to the front Plate.
Make sure it's level otherwise you will have inconsistent nozzle height.
Make sure the screws are tight. I've had these screws loosen up on me after 2 weeks.
Using 2x M2 washers and 2x M2x8 button head screws mount the X Endstop on the rear late above the upper belt. Make sure the endstop lever is facing down
The original design has the BLTouch mounted on the rear of the carriage using 2x M3x6 button head screws to secure the mount to the Rear Plate.
Secure the BLTouch to the rear mount with 2x M3x8 button head screws and 2x M3 nuts
Secure the mount to the Front Plate with 2x M3x6 button head screws
Secure the BLTouch to the Front Mount with 2x M3x10 button head screws and 2x M3 nuts
The screw needs to protrude out the opposite side enough to trigger the endstop before the BLTouch mount hits. About 2-3mm
Insert the Thermistor into the heat block and tighten the small set screw
Insert the heater cartridge into the heat block and tighten the M3 button head screw.
Install the silicone sock onto the heat block.
Using 2x M3x16 socket head screws secure the E3D and the E3D V6 Locker to the front plate.
Mount the 4010 fan with the longest wire into the block shield with 4x M3x12 screws
Insert the 2 blowers into the side mounts and secure with 2x M2.5x6 socket head screws(top) and 2x M2.5x12 socket head screws(bottom) on both sides.
Secure the block shield to the X Carriage with 5x M3x8 button head screws. Don't forget about the screw on the front.
Wiring is really a personal preference but I like everything as neat as possible which is why I made a wire locker mount for the metal kit. You can find the files in the FYSETC Modified Printed Parts folder on my Github
Note-This will not work if you have the BLTouch on the rear of the carriage
Using 2x M3x6 button head screws and 1x M3x10 button head screw mount the Wire Locker to the Rear Plate
Insert the hotend wires into the wire loom.
If you have a 24" zip-tie insert it into the wire loom with the wires(not included with the kit). This will help keep the wire loom up
Using a small zip-tie, lock the wire loom into the wire locker
Mount the Main_Cable_Tube_Holder to the rear of the frame using 2x M5x8 button head screws and 2x M5 T-nuts
6 personas más completaron esta guía.
