Introducción
Have you ever wanted to improve your 68cc gas bike's performance? This FastFix will help you improve your bikes performance and speed.
Qué necesitas
Clean the compression head with an alcohol based cleaner to ensure a perfect fit on the engine.
Place your 3/8" wrench on any of the four top cap nuts on the compression head currently on the bike.
Turn the wrench counter clock wise to loosen the cap nut and remove it. Then remove the washer and the locking washer. Repeat this for all cap nuts.
Keep the washers and lock washers with the cap nut they were with on the compression head, it is not recommended to mix them up.
Remove the compression head by lifting up.
Remove the head gasket from the engine. Sometimes the head gasket gets stuck to the compression, remove the head gasket if it is stuck to the compression head.
Clean metal head gasket with the rubbing alcohol.
Reinstall metal head gasket on the engine after cleaning.
This is nut #1, the one on the right closest to the camera.
This is nut #2, the one on the right farthest from the camera.
This is nut #3, the one on the right farthest from the camera.
This is nut #4, the one on the left closest to the camera.
Pay close attention to the relation of the nuts to the carburetor and the exhaust.
Using your 3/8” wrench, place it on the first cap nut labeled in the picture above. This is the cap nut in the red circle. Tighten it 2 full turns clock wise.
Next, place the wrench on cap screw three and tighten it 2 full turns clock wise. Cap screw three is the one labeled with by yellow arrows or circles.
9 personas más completaron esta guía.
