Saltar al contenido principal
4Sight 9 Battery Replacement
Qué necesitas
  1. 4Sight 9 Battery Replacement, Cover: paso 1, imagen 1 de 2 4Sight 9 Battery Replacement, Cover: paso 1, imagen 2 de 2
    • Place the tablet on its side so that the two screws are facing upward.
    • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
  2. 4Sight 9 Battery Replacement: paso 2, imagen 1 de 1
    • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
    • Once loosened, use your hands to separate the case from the device.
  3. 4Sight 9 Battery Replacement: paso 3, imagen 1 de 2 4Sight 9 Battery Replacement: paso 3, imagen 2 de 2
    • Hold the positive and negative wires as close as possible to the speaker.
    • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
  4. 4Sight 9 Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
    • For a complete guide on how to solder, click here.
  5. 4Sight 9 Battery Replacement: paso 5, imagen 1 de 2 4Sight 9 Battery Replacement: paso 5, imagen 2 de 2
    • Insert plastic prying tool under upper-hand corner of battery and slide back and forth.
    • Once loosened, insert plastic prying tool under lower-hand corner and repeat sliding action.
    • Repeat previous actions until battery comes loose from device.
Conclusión
7 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 1,641
