Saltar al contenido principal
46 ⅝” Inline Systems Desk Keyboard Tray Replacement
Qué necesitas
  1. 46 ⅝” Inline Systems Desk Keyboard Tray Replacement, Keyboard Tray: paso 1, imagen 1 de 3 46 ⅝” Inline Systems Desk Keyboard Tray Replacement, Keyboard Tray: paso 1, imagen 2 de 3 46 ⅝” Inline Systems Desk Keyboard Tray Replacement, Keyboard Tray: paso 1, imagen 3 de 3
    • Clear the desk tray of any objects or items.
  2. 46 ⅝” Inline Systems Desk Keyboard Tray Replacement: paso 2, imagen 1 de 1
    • Gently slide out the old tray from the table.
  3. 46 ⅝” Inline Systems Desk Keyboard Tray Replacement: paso 3, imagen 1 de 1
    • Remove the eight total 15 mm square socket screws that are securing both of the rails with a screwdriver.
  4. 46 ⅝” Inline Systems Desk Keyboard Tray Replacement: paso 4, imagen 1 de 1
    • Clean the first railing for the desk tray after taking off its 4 screws, and check for any damage. Repeat the process for the other railing.
  5. 46 ⅝” Inline Systems Desk Keyboard Tray Replacement: paso 5, imagen 1 de 2 46 ⅝” Inline Systems Desk Keyboard Tray Replacement: paso 5, imagen 2 de 2
    • Place each rail back to the desk and secure it with the screws.
    • Be sure to replace any screw with a new one if it is damaged or broken.
  6. 46 ⅝” Inline Systems Desk Keyboard Tray Replacement: paso 6, imagen 1 de 1
    • Gently align and insert the new tray into the railings once all the screws and railings are back in place.
  7. 46 ⅝” Inline Systems Desk Keyboard Tray Replacement: paso 7, imagen 1 de 3 46 ⅝” Inline Systems Desk Keyboard Tray Replacement: paso 7, imagen 2 de 3 46 ⅝” Inline Systems Desk Keyboard Tray Replacement: paso 7, imagen 3 de 3
    • Test the movement of the keyboard tray by pushing it all the way in and pulling it all the way out to ensure it works normally.
Conclusión
Now that the keyboard tray has been properly replaced, you can use your desk again.
Hasan
Miembro Desde 01/14/24
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 94
