Saltar al contenido principal
4-Stroke Small Gas Engine Spark Plug Replacement
Qué necesitas
  1. 4-Stroke Small Gas Engine Spark Plug Replacement, Spark Plug: paso 1, imagen 1 de 3 4-Stroke Small Gas Engine Spark Plug Replacement, Spark Plug: paso 1, imagen 2 de 3 4-Stroke Small Gas Engine Spark Plug Replacement, Spark Plug: paso 1, imagen 3 de 3
    • Tug the Spark Plug Cap from the top of the Spark Plug (between the OHV housing and the exhaust manifold) with your hands to remove it.
  2. 4-Stroke Small Gas Engine Spark Plug Replacement: paso 2, imagen 1 de 2 4-Stroke Small Gas Engine Spark Plug Replacement: paso 2, imagen 2 de 2
    • Make sure the engine is turned off and cool to the touch before completing this step.
    • Using a ¼ “ socket and Handheld Ratchet, loosen the three screws holding the Exhaust Manifold Heat Shield on.
  3. 4-Stroke Small Gas Engine Spark Plug Replacement: paso 3, imagen 1 de 3 4-Stroke Small Gas Engine Spark Plug Replacement: paso 3, imagen 2 de 3 4-Stroke Small Gas Engine Spark Plug Replacement: paso 3, imagen 3 de 3
    • Once the Heat Shield is removed, grip the Spark Plug’s threaded diameter with an Adjustable wrench and rotate counterclockwise.
    • Alternatively, you may use a 5/8" wrench or 5/8" deep socket along with a handheld ratchet.
    • Remove the Champion RC12YC Spark Plug from the device.
Conclusión
2 personas más completaron esta guía.
Jack Linchey
Miembro Desde 04/19/18
277 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S25-G15, Maness Spring 2018 Miembro de Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 1,323
