Saltar al contenido principal
4-Pole Headphone Jack Replacement
Qué necesitas
  1. 4-Pole Headphone Jack Replacement, 4-Pole 3.5mm Jack: paso 1, imagen 1 de 1
    • Cut the headphone cable near the old headphone jack. Leave some cable attached to the jack.
  2. 4-Pole Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Cut open the outer insulation of the cable connected to the old jack to expose the internal wires.
  3. 4-Pole Headphone Jack Replacement: paso 3, imagen 1 de 1
    • Apply a small amount of solder to the tips of each of the internal wires.
    • Make use of the Helping Hand tool to hold the wires while you apply the solder and iron.
    • Do not touch the soldering iron to the wire for a long period of time, you may melt through the wire.
  4. 4-Pole Headphone Jack Replacement: paso 4, imagen 1 de 1
    • Turn on the multimeter and set it to measure resistance.
    • Select a wire and touch one of the multimeter leads to the soldered tip.
    • Touch the other multimeter lead to each of the segments on the headphone jack until the multimeter indicates that the wire is connected.
    • Make sure to record what wire is connected to what pole of the jack.
    • Repeat the process for each wire.
  5. 4-Pole Headphone Jack Replacement: paso 5, imagen 1 de 1
    • Cut away the insulation on the wire connected to the headphones.
  6. 4-Pole Headphone Jack Replacement: paso 6, imagen 1 de 1
    • Select an appropriately sized piece of shrink tubing.
    • Slide the tubing over the wire.
  7. 4-Pole Headphone Jack Replacement: paso 7, imagen 1 de 1
    • Select a wire and apply a small amount of solder to the tip of the wire.
    • Repeat this for every wire.
  8. 4-Pole Headphone Jack Replacement: paso 8, imagen 1 de 1
    • Position a wire to the corresponding connection point on the jack.
    • Carefully apply a small amount of solder to hold the wire in place.
    • Repeat this for each wire.
    • Make sure to reference the mapping of wires to connection points that you created in Step 4.
    • When soldering the wires, be patient and meticulous about getting the right position to make a good connection.
    • If the internal wires do not have their own insulation, use a small bit of shrink tubing on each wire. This will prevent them from shorting across another wire.
  9. 4-Pole Headphone Jack Replacement: paso 9, imagen 1 de 1
    • Slide the shrink tubing back over the base of the jack, covering the soldered connections.
  10. 4-Pole Headphone Jack Replacement: paso 10, imagen 1 de 1
    • Use the flat side of the soldering iron to apply heat to the shrink tubing until it tightens on the wire.
    • Alternatively, you could also use a heat gun or hair dryer.
Conclusión
You have now completed the replacement process. Plug it into an audio source and play some music to test your work.
28 personas más completaron esta guía.
Matthew Vaught
Miembro Desde 03/30/16
1,028 Reputación
1 Guía escrita
Equipo
13 comentarios
This is a plug replacement, not a jack replacement.
Wes Hartman - Contestar
This is a jack replacement.
Jonathan Harper -
can you please tell me which color wire and where to solder !
Sujith Kumar John G - Contestar
Wire colors are not standardized. They even differ among models of the same manufacturer. The only way is to test against the plug that is being replaced. Hopefully most wires still connect to the plug contacts, so a process of elimination can be used. Typical colors are red, blue, green and no color. Ground is usually no color, and sometimes there are 2 grounds (e.g. for ‘zipper’ style wires). The contacts for most phones are as follows (from tip to outside barrel): Right, Left, Ground, Mic. My Samsung S3 cord was very strange: red, green, no color and 2 black wires. One black was Ground, the other was MIC. Soldering requires a magnifier and a fine tipped iron.
Bert490 - Contestar
No pinout, seriously?
Old Liquid - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 30
Ultimos 7 días: 216
Ultimos 30 días: 878
Todo El Tiempo: 198,029
