Saltar al contenido principal
3DR Solo Propeller Disassembly
  1. 3DR Solo Propeller Disassembly, Propeller: paso 1, imagen 1 de 1
    • Grip the arm, which is located underneath the propeller, with one hand, and with your dominant hand grip the center of the propeller.
  2. 3DR Solo Propeller Disassembly: paso 2, imagen 1 de 1
    • Twist the propeller from the locked to unlocked position as indicated by the images of the lock.
    • You will need to twist in this direction for 2-3 full rotations before the propeller will detach.
  3. 3DR Solo Propeller Disassembly: paso 3, imagen 1 de 1
    • Lift the propeller off the motor.
    • To remove the silver-top propellers, repeat these steps, turning the propellers in the opposite direction of the black-top propellers.
Conclusión
Lauren Hays
Miembro Desde 09/11/17
222 Reputación
2 Guías creadas
Equipo
CSU Fullerton, Team S2-G3, Bruce Fall 2017 Miembro de CSU Fullerton, Team S2-G3, Bruce Fall 2017
CSUF-BRUCE-F17S2G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 564
